Heart Rate Features
The vívomove® Sport device has a heart rate menu, enabling you to view wrist-based heart rate data.
Monitors the saturation of oxygen in your blood. Knowing your oxygen saturation can help you determine how your body is adapting to exercise and stress (Getting Pulse Oximeter Readings).
NOTE:
The pulse oximeter sensor is located on the back of the device.
Displays your current VO2 max., which is an indication of athletic performance and should increase as your level of fitness improves (Getting Your VO2 Max. Estimate). |
Displays your current fitness age, which is based on your VO2 max., resting heart rate, and body mass index (BMI). (Viewing Your Fitness Age) For the most accurate fitness age, complete the user profile setup in your Garmin Connect™ account. |
Broadcasts your current heart rate to a paired Garmin® device (Broadcasting Heart Rate Data to Garmin Devices). |
