Mode S Transponder
The AXIS™ is capable of interfacing with several remote transponders providing Mode S interrogation and reply capabilities. Selective addressing or Mode Select (Mode S) capability includes the following features:
  • Level-2 reply data link capability (used to exchange information between aircraft and ATC facilities)
  • Surveillance identifier capability
  • Flight ID (Flight Identification) reporting – The Mode S Transponder reports aircraft identification as either the aircraft registration or a Flight ID.
  • Altitude reporting
  • Airborne status determination
  • Transponder capability reporting
  • Mode S Enhanced Surveillance (EHS) requirements
  • Acquisition squitter – Acquisition squitter, or short squitter, is the transponder 24-bit identification address. The transmission is sent periodically, regardless of the presence of interrogations. The purpose of acquisition squitter is to enable Mode S ground stations and aircraft equipped with a Traffic Avoidance System (TAS) to recognize the presence of Mode S-equipped aircraft for selective interrogation.
  • Extended squitter – The extended squitter is transmitted periodically and contains information such as altitude (barometric and GPS), GPS position, and aircraft identification. The purpose of extended squitter is to provide aircraft position and identification to ADS-B Ground-Based Transceivers (GBTs) and other aircraft.
The Traffic Avoidance portion of the Hazard Avoidance section provides more details on traffic avoidance systems.
190-03123-01 Rev B
July 2026
