Connecting to Power
WARNING
The wiring (not included) from the power source to the positive wire of the power wiring harness must run through a circuit breaker or in-line fuse (not included) as close to the power source as possible. See the ABYC or your local and regional standards for the required fuse or breaker rating. Connecting the device to power without a circuit breaker or in-line fuse may cause a fire if there is a short in the cable, resulting in property damage and/or serious personal injury.
NOTICE
The power supply voltage to the LED control module must match the voltage of the LED lighting it is controlling. Mixing 12 Vdc and 24 Vdc devices may damage your LED lighting.
  1. Route 16 AWG marine-grade, fully-tinned copper wire (not included) to the wiring harness and the common ground location on the boat, and select an option:
    • Install a properly rated in-line fuse on the red power wire as close to the power source as possible.
    • Identify or install a properly rated circuit breaker, as close to the power source as possible, for use with the power wire.
  2. Install marine-grade connectors or solder and heat shrink tubing on both the red power and black ground wires.
    NOTE: The pink and black wire is for an optional toggle switch, and must not be connected to the ignition (Connecting an Optional Momentary Switch).
  3. Connect the power plug.
GUID-6A3E1D9B-1E17-4069-BF5C-3C82F2202A9B v4
September 2025
