Connecting an Optional Momentary Switch
You can connect an optional, normally open momentary switch to the Garmin Spectra™ LED Control Module to toggle all connected LED lights on and off without using a connected chartplotter, stereo, or app. When toggling lights on, the LEDs will restore the last-used lighting configuration.
- Connect the pink and black wire on the power wiring harness to the same ground connection as the negative wire through a normally open momentary switch (not included).
- If necessary, mount or install the switch according to the instructions provided with the switch.
- Connect the power wiring harness to the LED control module.
Parent Topic: Connecting to Power
