Laser Locations
While you are hunting with your device, it creates a record of the heading and ranged distance each time you range a target. You can send this data to a compatible Garmin® watch or handheld device. This can be help you to create waypoints or track game. Laser locations appear in the XERO Locations widget or app on your compatible device. You can adjust the broadcast settings from the settings menu on your bow sight (Xero Location Settings).
NOTE:
You may need to update the software for your compatible watch or handheld device before you can use the
XERO Locations app (Product Updates).
Parent Topic: Using the Scope
