Display Overview
Displays the direction in which you are pointing the device when you range the target. |
Displays the aim point for the measured distance. |
Indicates the crossbow is tilted. |
Indicates how steady you are holding the crossbow. The circle expands and contracts with the crossbow motion while aiming. |
Displays the angle at which the crossbow is tilted, in degrees. |
Displays the measured distance between the laser rangefinder and the target. |
Displays the horizontal distance to the target, which is calculated using the angle of measurement. |
Displays the upward or downward angle from the rangefinder to the target. |
Displays a digital level showing the angle at which the crossbow is tilted. |
Displays the remaining battery power. |
Displays the number of shots taken in the current shooting session. |
Displays the impulse duration of the previous shot, in milliseconds. |
Displays the roll measurement of the previous shot. |
Displays the remote trigger cable connection status. |
