Adding Aim Points
You can add aim points to an existing bolt profile to calibrate it for a specific distance.
- From the main menu, select PROFILE.
- Select a bolt profile.
- Select .
Select an option:
To manually calibrate a new aim point, select CALIBRATED RANGE.
To add a fixed aim point based on your calibrated ranges, select FIXED AIM POINT.
- Follow the on-screen instructions to calibrate the aim point.
Parent Topic: Adding Bolt Profiles
