Setting the Ranging Mode
You can adjust the ranging mode to work more effectively in your hunting environment. For the best results in each ranging mode, you should hold the ranging button until TARGET LOCKED appears.
- From the quick options menu, select RANGING MODE.
Select an option:
To display the most recent value measured by the range finder, select RECENT. This option is ideal for most environments.
To display the closest range measured by the range finder, select MINIMUM. This option is useful when the target is far away and positioned in front of a backdrop, such as a group of trees.
To display the farthest range measured by the range finder, select MAXIMUM. This option is useful when the target is in wooded conditions where the range finder might detect leaves or other interference.
