Level Settings
From the main menu, select .
- TARE
Sets the level to zero for the current angle.
- AIM POINT LEVEL
Sets the angle indicator to appear with the measured aim point (Display Overview).
- LEVEL GAUGE
Sets the level gauge to appear on the display. The level gauge shows the angle at which the crossbow is tilted, in degrees.
- BUBBLE LEVEL
Sets the bubble level to appear on the display. The bubble level provides a quick visual indicator of how severely the crossbow is tilted. For best accuracy, you should always keep the bubble level centered while shooting the crossbow.
- SENSITIVITY
Sets the level sensitivity to low, medium, or high. Low sensitivity sets the tilt indicators to appear when the crossbow is tilted five degrees or more. Medium sensitivity sets the tilt indicators to appear when the crossbow is tilted three degrees or more. High sensitivity sets the tilt indicators to appear when the crossbow is tilted one degree or more.
- RESET TARE
Resets the level calibration to the factory default value.
