Activating or Editing Bolt Profiles
- From the main menu, select PROFILE.
- Select a bolt profile.
Select an option:
To activate a profile, select ACTIVATE.
To adjust the aim points for the selected profile, select AIM POINTS.
To change the bow speed, select BOW SPEED.
NOTE: The bow speed option appears only if you auto-calibrated aim points while creating the bolt profile. -
To validate aim points for an auto-calibrated profile, select VALIDATE.
To edit the profile name, select EDIT NAME.
To reset all calibration data for the current profile, select RESET PROFILE.
To copy the profile data to a new profile, select COPY PROFILE.
To delete the profile, select DELETE.
Parent Topic: Adding Bolt Profiles
