Mounting Considerations
NOTICE
This device is designed for installation only in a dry location. Installing this device in a location where it may come in contact with water or become submerged may result in damage. Water damage is not covered by the warranty.
NOTICE
You must turn off the audio system before making any connections to the source unit, amplifier, or speakers. Failure to do so could result in permanent damage to the audio system.
NOTICE
You should protect all terminals and connections from grounding and from each other. Failure to do so could result in permanent damage to the audio system and void the product warranty.
NOTICE
The mounting method and materials used can vary depending on the vehicle application.
When mounting the speakers, observe these considerations.
  • There must be sufficient clearance for the mounting depth of the speakers as specified in the product specifications.
  • The mounting surface should be flat for the best seal.
  • You should protect the speaker wires from sharp objects, and always use grommets when wiring through panels.
GUID-646627E3-A1E7-4EC4-BE08-216FEA26B9C3 v1
July 2025
