Device Settings
On the Varia™ app, select the device icon at the top of the home screen, and select Device Settings.
Speed Indicator
Shows or hides the speed indicator on the Varia app radar screen.
Location
Sets the placement of the speed indicator on the Varia app screen.
Measurement Units
Sets the measurement unit for the speed indicator on the Varia app screen.
Device Orientation
Sets the orientation in which the device is installed on the mount.
NOTE: By default, the device automatically detects its orientation. If you manually set the orientation, the device does not notify you of orientation errors, and you must make sure the setting matches the actual device orientation.
Brake Light Pattern
Sets a flashing pattern for the tail light to use when the device detects that you are slowing down.
GUID-50AF77F9-6AD5-45A2-B352-C882BE5DE2B7 v2
August 2026
