Charging the Device
NOTICE
To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer.
NOTICE
The device can operate normally while charging. If you use the device while charging, Garmin® recommends using a cable with a right-angle connector (not included) to avoid strain on the device charging port.
  1. Pull up the weather cap 1, and plug the USB cable into the charging port 2 on the device.
    Back view of the device with callouts
  2. Connect the other end of the USB-C® cable to a power supply, such as a charging port or AC adapter (not included).
After charging for 15 minutes, the device has at least 2 hours of battery life, depending on the light mode. It takes up to 2.5 hours to complete a full charge.
The status LED flashes Green to indicate the charging status.
GUID-50AF77F9-6AD5-45A2-B352-C882BE5DE2B7 v2
August 2026
