Swimming
NOTICE
The device is intended for surface swimming. Scuba diving with the device may damage the product and will void the warranty.
NOTE: The watch has wrist-based heart rate enabled for swim activities.
Swim Terminology
Length
One trip down the pool.
Interval
One or more consecutive lengths. A new interval starts after a rest.
Stroke
A stroke is counted every time your arm wearing the watch completes a full cycle.
Swolf
Your swolf score is the sum of the time for one pool length and the number of strokes for that length. For example, 30 seconds plus 15 strokes equals a swolf score of 45. For open water swimming, swolf is calculated over 25 meters. Swolf is a measurement of swimming efficiency and, like golf, a lower score is better.
Stroke Types
Stroke type identification is available only for pool swimming. Your stroke type is identified at the end of a length. Stroke types appear in your swimming history and in your Garmin Connect™ account. You can also select stroke type as a custom data field (Customizing the Data Screens).
Free
Freestyle
Back
Backstroke
Breast
Breaststroke
Fly
Butterfly
Mixed
More than one stroke type in an interval
Drill
Used with drill logging (Training with the Drill Log)
Tips for Swimming Activities
  • Press Lower-right button to record an interval during open water swimming.
  • Before starting a pool swimming activity, follow the on-screen instructions to select your pool size or enter a custom size.
    The watch measures and records distance by completed pool lengths. The pool size must be correct to display accurate distance. The next time you start a pool swimming activity, the watch uses this pool size. You can scroll down to select the activity settings, and select Pool Size to change the size.
  • For accurate results, swim the entire pool length, and use one stroke type for the entire length. Pause the activity timer when resting.
  • Press Lower-right button to record a rest during pool swimming (Swim Auto Rest and Manual Rest).
    The watch automatically records swim intervals and lengths for pool swimming.
  • To help the watch count your lengths, use a strong push off the wall and glide before your first stroke.
  • When doing drills, you must either pause the activity timer or use the drill logging feature (Training with the Drill Log).
The auto rest feature is available only for pool swimming. Your watch automatically detects when you are resting, and the rest screen appears. If you rest for more than 15 seconds, the watch automatically creates a rest interval. When you resume swimming, the watch automatically starts a new swim interval.
TIP: For best results using the auto rest feature, minimize your arm motions while resting.
To use manual rests instead, you can turn off the auto rest feature in the activity options (Activity Settings). During a pool or open water swim activity, you can manually mark a rest interval by pressing Lower-right button. Swim data is not recorded during a rest interval.
TIP: Use manual rests if you are taking short rests or you want very precise swim interval timing.
The drill log feature is available only for pool swimming. You can use the drill log feature to manually record kick sets, one-arm swimming, or any type of swimming that is not one of the four major strokes.
  1. During your pool swim activity, scroll up or down to view the drill log screen.
  2. Press Lower-right button to start the drill timer.
  3. After you complete a drill interval, press Lower-right button.
    The drill timer stops, but the activity timer continues to record the entire swim session.
  4. Select a distance for the completed drill.
    Distance increments are based on the pool size selected for the activity profile.
  5. Select an option:
    • To start another drill interval, press Lower-right button.
    • To start a swim interval, scroll up or down to return to the swim training screens.
    After you complete the drill, the activity enters rest mode.
  6. Select an option:
    • To resume the activity, press Lower-right button.
    • To end the activity, press Upper-right button.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
