Customizing the Data Screens
You can show, hide, and change the layout and content of data screens for each activity.
  1. From the watch face, press Upper-right button.
  2. Select Activities, and select an activity.
  3. Scroll down, and select the activity settings.
  4. Select Data Screens.
  5. Scroll to the data screen you want to customize.
  6. Select Edit symbol.
  7. Select an option:
    • Select Layout to adjust the number of data fields on the data screen.
    • Select Data Fields, and select a field to change the data that appears in the field.
      TIP: For a list of all the available data fields, go to Data Fields. Not all data fields are available for all activity types.
    • Select Reorder to change the location of the data screen in the loop.
    • Select Remove to remove the data screen from the loop.
  8. If necessary, select Add New to add a data screen to the loop.
    You can add a custom data screen, or select one of the predefined data screens.
Adding the Map Data Screen
You can add the map to the data screens loop for a GPS activity.
  2. Select Activities, and select a GPS activity.
  4. Select Data Screens > Add New > Map.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
