Module Status LED
LED Activity |
Status |
Flashing
The module is in active pairing mode. The device is in pairing mode for 5 minutes. |
Solid
The module is paired. |
Flashing
The module is turning on. |
Flashing
The module is charging. As the charge increases, the flash period increases until it is fully charged. |
Solid
The module is fully charged. |
Alternating
The module is updating software. |
Flashing
Pairing failed or the battery level is critically low. You should pair again, or charge the module (Pairing Your Device with the Garmin Connect App). |
Solid
An error occurred. You may need to reset the module (Resetting the Device). |
Alternating
The module is resetting to factory default values. |
