Radar Setup Menu
From a radar screen, select Options > Radar Setup.
Source
Selects the radar source when more than one radar is connected to the network.
Chart Display
Shows the chart under the radar image. When enabled, the Layers menu appears.
Orientation
Sets the perspective of the radar display.
Crosstalk Rej.
Reduces the appearance of clutter caused by interference from another nearby radar source.
Rotation Spd.
Sets the preferred speed at which the radar rotates. The High Speed option can be used to increase the refresh rate. In some situations, the radar automatically rotates at the normal speed to improve detection, for example, when a longer range is selected or when MotionScope or Dual range is used.
Appearance
Sets the color scheme, look-ahead speed, and navigation appearance.
Installation
Allows you to configure the radar for the installation, such as setting the front of the boat and the antenna park position.
January 2025
