Moving a Saved Waypoint
  1. Select Info > User Data > Waypoints.
  2. Select a waypoint.
  3. Select Review > Edit > Position.
  4. Indicate a new location for the waypoint:
    • To move the waypoint using coordinates, select Enter Coordinates, enter the new coordinates, and select Done or Cancel.
    • To move the waypoint while using the chart, select Use Chart, select a new location on the chart, and select Move Waypoint.
    • To move the waypoint using the vessel's current position, select Use Current Position.
    • To move the waypoint using a range (distance) and bearing, select Enter Range/Bearing, enter the information, and select Done.
January 2025
