GPSMAP 9x3 Specifications
Dimensions (W × H × D) |
233.0 × 162.3 × 75.8 mm (9 3/16 × 6 3/8 × 3 in.) |
Dimensions with cover on bail mount (W × H × D) |
256.2 × 178.1 ×104.7 mm (101/16 x 7 x 41/8 in.) |
Clearance to next obstruction behind chartplotter |
33.2 mm (15/8 in.) |
Display size (W × H) |
198.7 × 111.8 mm (7 13/16 × 4 3/8 in.) 22.9 cm (9.0 in.) diagonal |
Display resolution |
WXGA, 1280 ×720 pixels |
Weight |
1.6 kg (3.6 lb.) |
Compass-safe distance |
30 cm (11.81 in.) |
Max. power usage at 10 Vdc |
Non-sonar models: 22.0 W Sonar models: 40.2 W |
Typical current draw at 12 Vdc |
Non-sonar models: 1.34 A Sonar models: 1.37 A |
Max. current draw at 12 Vdc |
Non-sonar models: 1.78 A Sonar models: 3.20 A |
Temperature range |
From -15° to 55°C (from 5° to 131°F) |
Material |
Polycarbonate plastic and die-cast aluminum |
Water rating |
IEC 60529 IPX7 1 |
Input voltage |
From 10 to 32 Vdc |
Fuse |
6 A, 125 V fast-acting |
NMEA 2000® LEN @ 9 Vdc |
2 |
NMEA 2000 draw |
75 mA max. |
Max. waypoints |
5,000 |
Max. routes |
100 |
Max. active track points |
50,000 points, 50 saved tracks |
Wireless frequency |
2.4 GHz @ 17.6 dBm maximum |
Memory card |
2 microSD® card slots; 32 GB max. card size |
