GPSMAP 7x2 Plus Specifications
Dimensions (W × H × D) |
224.7 × 142.2 × 54.0 mm (87/8 × 55/8 × 21/8 in.) |
Dimensions with cover on bail mount (W × H × D) |
257.1 × 162.0 × 83.1 mm (101/8 × 63/8 × 31/4) |
Clearance to next obstruction behind chartplotter |
84.3 mm (35/16 in.) |
Display size (W × H) |
155.1× 86.9 mm (61/8 × 37/16 in.) 177.8 mm (7 in.) diagonal |
Display resolution |
WVGA, 800 × 480 pixels |
Weight |
0.86 kg (1.9 lb.) |
Compass-safe distance |
71 cm (28 in.) |
Temperature range |
From -15° to 55°C (from 5° to 131°F) |
Material |
Polycarbonate plastic and die-cast aluminum |
Water rating |
IEC 60529 IPX71 |
Fuse |
6 A, 125 V fast-acting |
Input voltage |
From 10 to 32 Vdc |
Max. power usage at 10 Vdc |
24 W |
Typical current draw at 12 Vdc |
1.5 A |
Max. current draw at 12 Vdc |
2.0 A |
NMEA 2000® LEN @ 9 Vdc |
2 |
NMEA 2000 draw |
75 mA max. |
Max. waypoints |
5,000 |
Max. routes |
100 |
Max. active track points |
50,000 points, 50 saved tracks |
Wireless frequency |
2.4 GHz @ 17.6 dBm maximum |
Memory card |
2 SD® card slots; 32 GB max. card size |
HTML integration |
Compatible with OneHelm™ integration (Plus models only) |
