Creating a Group
Before you can create a group, you must connect multiple compatible stereos to the Fusion PartyBus™ network. See the installation instructions provided with your stereo for information about installing and configuring the network.
NOTE: There are some limitations and other considerations when using stereos in groups. See Grouped Stereo Source Considerationsfor more information.
  1. Select Menu button > GROUPS.
    TIP: You can hold Source button from any screen to open the GROUPS menu.
  2. Select the name of the stereo you want to be the primary stereo in the group.
  3. Select the stereos you want to add to the group.
  4. Select DONE.
From the source screen, you can select a source from any stereo in the group except a zone stereo, such as the Fusion Apollo™ SRX400 stereo or any sources that are disabled for use on the Fusion PartyBus network (General Settings).
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
