Grouped Stereo Source Considerations
When selecting sources to play over the network, you should observe these considerations.
A zone stereo, such as the Fusion Apollo™ SRX400, can create or join a group to control and play sources from other stereos, but it cannot share its sources with the group.
You cannot share an AirPlay® source with grouped stereos. Using AirPlay 2 software, you can play content on multiple stereos on the network, but the stereos must not be grouped (Connecting an Apple Device Using AirPlay).
You can disable sharing on most sources by changing the GROUP ENABLED setting for the source. When disabled, the source cannot be selected from a grouped stereo (General Settings).
When audio sources are streamed over a data network, there is a slight delay in the synchronized audio that may be noticeable if you are also using an external audio source.
If you have a television with an Optical Out connection to a stereo and you continue to use the television speakers, there will be a delay between the audio from the television speakers and the optical audio streamed on the grouped stereos.
If you synchronize a radio station and tune that same radio station on a non-networked stereo, there will be a delay between the audio from the non-networked stereo and the audio from the radio station streamed on the grouped stereos.
You can remove this delay by changing the GROUP ENABLED setting for the source, but the source cannot be shared with grouped stereos (General Settings).
