Maintaining Individual Zone Volume Levels
If you adjust the volume levels of individual zones so that some zones are louder than others, the individual zone volume settings are all affected when you adjust the volume for ALL zones. By default, if you adjust the volume for ALL to 00, this sets of the volume levels for all zones to 00 and resets all individual zone volume adjustments. You can enable the KEEP VOLUME RATIOS option to retain individual zone volume adjustments when you adjust the volume for ALL to 00.
NOTE:
This setting applies to volume adjustments on the stereo or a connected
Fusion Apollo™ ERX400 remote control only.
If you adjust the volume on the stereo using a connected chartplotter or
NRX remote control, the volume levels will still be reset.
TIP:
For the best results when enabling this setting, you should set the power-on volume limit to 24 (Adjusting the Power-On Volume Limit).
- Select .
- Select the name of the remote control.
- Select KEEP VOLUME RATIOS.
Parent Topic: Speaker Zone Settings
