Adjusting the Power-On Volume Limit
By default, when you turn on the stereo, the system automatically reduces the volume to level 12 if it was louder than that when you turned it off. You can adjust this limit if you want to retain a louder volume or limit to a lower volume when you turn on the stereo.
NOTE: This setting affects all zones on the stereo.
  1. Select Menu button > SETTINGS.
  2. Select the name of the stereo.
  3. Select ZONE > POWER ON VOLUME LIMIT.
  4. Adjust the volume limit.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
