You can use the auto climb feature to detect elevation changes automatically. You can use it during activities such as climbing, hiking, running, or biking.
Hold
Select
Select an activity.
NOTE:
This feature is not available for all activities.
Select the activity settings.
Select
Select
Always or
When Not Navigating.
Select an option:
Select
Run Screen to identify which data screen appears while running.
Select
Climb Screen to identify which data screen appears while climbing.
Select
Invert Colors to reverse the display colors when changing modes.
Select
Vertical Speed to set the rate of ascent over time.
Select
Mode Switch to set how quickly the device changes modes.
NOTE:
The
Current Screen option allows you to automatically switch to the last screen you were viewing before the auto climb transition occurred.
