Activities and App Settings
These settings allow you to customize each preloaded activity app based on your needs. For example, you can customize data pages and enable alerts and training features. Not all settings are available for all activity types.
Hold , select Activities & Apps, select an activity, and select the activity settings.
- 3D Distance
Calculates your distance traveled using your elevation change and your horizontal movement over ground.
- 3D Speed
Calculates your speed using your elevation change and your horizontal movement over ground.
- Accent Color
Sets the accent color of each activity to help identify which activity is active.
- Add Activity
Allows you to customize a multisport activity.
- Alerts
Sets the training or navigation alerts for the activity (Activity Alerts).
- Auto Climb
Enables the watch to detect elevation changes automatically using the built-in altimeter (Enabling Auto Climb).
- Auto Lap
Sets the options for the Auto Lap® feature to automatically mark laps. The Auto Distance option marks laps at a specific distance. When you complete a lap, a customizable lap alert message appears. This feature is helpful for comparing your performance over different parts of an activity.
- Auto Pause
Sets the options for the Auto Pause® feature to stop recording data when you stop moving or when you drop below a specified speed. This feature is helpful if your activity includes stop lights or other places where you must stop.
- Auto Rest
Enables the watch to automatically create a rest interval when you stop moving (Auto Rest and Manual Rest).
- Auto Scroll
Sets the watch to scroll through all of the activity data screens automatically while the activity timer is running.
- Auto Set
Enables the watch to start and stop exercise sets automatically during a strength training activity.
- Auto Start
Sets the watch to automatically start a motocross or BMX activity when you start moving.
- Background Color
Sets the background color of each activity to black or white.
- Broadcast Heart Rate
Enables automatic heart rate data broadcasting when you start the activity (Broadcasting Heart Rate Data During an Activity).
- ClimbPro
Displays ascent planning and monitoring screens while navigating (Using ClimbPro).
- Countdown Start
Enables a countdown timer for pool swimming intervals.
- Data Screens
Enables you to customize data screens and add new data screens for the activity (Customizing the Data Screens).
- Driver Distance
Sets the average distance the ball travels on your drive while playing golf.
- Edit Weight
Allows you to add the weight used for an exercise set during a strength training or cardio activity.
- Golf Distance
Sets the unit of measure for distance while playing golf.
- Grading System
Sets the grading system for rating the route difficulty for a rock climbing activity.
- Handicap Scoring
Enables handicap scoring while playing golf. The Local Handicap option allows you to enter the number of strokes to be subtracted from your total score. The Index/Slope option allows you to enter your handicap and the course slope rating so the watch can calculate your course handicap. When you enable either handicap scoring option, you can adjust your handicap value.
- Lane Number
Sets your lane number for track running.
- Lap Key
Enables or disables the
button for recording a lap or rest during an activity.
- Lock Keys
Locks the buttons during a multisport activity to prevent inadvertent button presses.
- Map
Sets the display preferences for the map data screen for the activity (Activity Map Settings).
- Metronome
Plays tones or vibrates at a steady rhythm to help you improve your performance by training at a faster, slower, or more consistent cadence. You can set the beats per minute (bpm) of the cadence you want to maintain, beat frequency, and sound settings.
- Mode Tracking
Enables or disables automatic ascent or descent mode tracking for backcountry skiing and snowboarding.
- Pool Size
Sets the pool length for pool swimming.
- Power Averaging
Controls whether the watch includes zero values for bike power data that occur when you are not pedaling.
- Power Save Timeout
Sets the power-save timeout length for how long your watch stays in training mode, for example, when you are waiting for a race to start. The Normal option sets the watch to enter low-power watch mode after 5 minutes of inactivity. The Extended option sets the watch to enter low-power watch mode after 25 minutes of inactivity. The extended mode can result in shorter battery life between charges.
- Record Activity
Enables activity FIT file recording for golf activities. FIT files record fitness information that is tailored for Garmin Connect™.
- Record Temperature
Records the ambient temperature around the watch during certain activities.
- Record VO2 Max.
Enables VO2 max. recording for trail run and ultra run activities.
- Rename
Sets the activity name.
- Rep Counting
Enables or disables rep counting during a workout. The Workouts Only option enables rep counting during guided workouts only.
- Repeat
Enables the Repeat option for multisport activities. For example, you can use this option for activities that include multiple transitions, such as a swimrun.
- Restore Defaults
Allows you to reset the activity settings.
- Route Stats
Enables route statistics tracking for indoor climbing activities.
- Routing
Sets the preferences for calculating routes for the activity (Routing Settings).
- Running Power
Allows you to record running power data and customize the settings (Running Power Settings).
- Runs
Sets the preferences for ski or snowboard runs. You can enable Auto Run to detect runs automatically using the built-in accelerometer. You can also enable the Lap Key and the Lap Alert settings.
- Satellites
Sets the satellite system to use for the activity (Changing the Satellite Setting).
- Scoring
Enables or disables scorekeeping automatically when you start a round of golf. The Always Ask option prompts you when you begin a round.
- Scoring Method
Sets the scoring method to stroke play or Stableford scoring while playing golf.
- Segment Alerts
Enables prompts that alert you to approaching segments (Segments).
- Self Evaluation
Sets how often you evaluate your perceived effort for the activity (Evaluating an Activity).
- Stat Tracking
Enables statistics tracking while playing golf (Recording Statistics).
- Stroke Detect.
Enables stroke detection for pool swimming.
- Transitions
Enables transitions for multisport activities.
- Vibration Alerts
Enables alerts that notify you to inhale or exhale during a breathwork activity.
- Workout Videos
Enables instructive workout animations for a strength, cardio, yoga, or Pilates activity. Animations are available for pre-installed workouts and workouts downloaded from your Garmin Connect account.
- Customizing the Data Screens
- Adding a Map to an Activity
- Activity Alerts
- Activity Map Settings
- Routing Settings
- Auto Lap
- Enabling Auto Pause
- Using ClimbPro
- Enabling Auto Climb
- Enabling Self Evaluation
- 3D Speed and Distance
- Using Auto Scroll
- Changing the Satellite Setting
- Power Save Timeout Settings
