Setting a Custom Dive Alert
  1. Hold MENU.
  2. Select Dive Setup.
  3. Select an option:
    • Select Scuba Alerts.
    • Select Apnea Alerts.
  4. Select an option:
    • Select Add Alert to add a new alert.
    • Select the alert name to edit an existing alert.
  5. If necessary, enable the alert.
  6. Select an option:
    NOTE: Not all options are available for all alert types.
    • Select Depth to specify the depth that should trigger the alert.
    • Select Time to specify the time interval that should trigger the alert.
    • Select Speed to specify the vertical speed threshold that should trigger the alert.
      NOTE: You can set the alert to trigger when your vertical speed exceeds or drops below the selected speed.
    • Select Interval to specify if the alert should trigger once or at a repeat interval.
    • Select Direction to specify if the alert should be enabled for ascending, descending, or both.
    • Select Dive Types to specify which dive modes should allow the alert to trigger.
    • Select Sound and Vibe to set the alert tone, vibration, or neither.
    • Select Pop-up to enable a pop-up notification for the alert.
    • Select Preview Alert to see how the alert appears and sounds during a dive.
GUID-2A58ED2A-14A3-4161-ADB5-259E1781AF1B v7
July 2024
