Measuring bearing and distance between any two points:
  1. Touch and hold two fingers anywhere on the MFW map display. A gray Measurement Line is drawn where the map was touched, with cyan Measure Pointers on each end of the line.
  2. Touch and drag either cyan Measure Pointer to the desired location.
  3. Repeat Step 2 as desired to move either pointer again and measure any other point.
  4. When finished, touch anywhere on the map display to remove the measurement indications.
190-03123-21 Rev B
October 2026
