Datalink Weather
Do not use the indicated data link weather product age to ascertain the age of the weather information shown by the data link weather product. Due to time delays inherent in gathering and processing weather data for data link transmission, the weather information shown by the data link weather product may be older than the indicated weather product age.
Do not use datalink weather information for maneuvering in, near, or around areas of hazardous weather. Information contained within datalink weather products may not accurately depict current weather conditions.
Do not rely on datalink weather information to discern precise values for any weather-related measurements. Datalink weather information is presented for informational purposes only, and should never be used as a replacement for official sources of in-flight weather information.
The FIS-B Weather service, available when equipped with a capable transponder or data link receiver which can receive 978 MHz Universal Access Transceiver (UAT) data, delivers subscription-free weather information periodically and automatically to the aircraft. FIS-B uses a network of FAA-operated Ground-Based Transceivers (GBTs) to transmit the information to the aircraft’s receiver. Reception is limited to line-of-sight, and is available below 24,000 feet MSL in the United States. FIS-B broadcasts provide weather data in a repeating cycle which may take approximately ten minutes to transmit all available weather data. Therefore, not all weather data may be present immediately upon initial FIS-B signal acquisition. FIS-B is a component of the Automatic Dependent Surveillance (ADS-B) system, which offers both weather and traffic data; refer to the ADS-B Traffic discussion later in this section for a more detailed discussion of the ADS-B system and its capabilities.
The Garmin Connext® Weather service, available when equipped with the optional Garmin GSR 56 Iridium Transceiver and an active service subscription, provides data link weather information to the aircraft after the pilot defines a geographic area and subsequently selects a manual or automatically recurring Connext Data Request. The transceiver then contacts the Garmin Connext Weather service using the Iridium Satellite telephone system and retrieves the weather data for the specified area. The Garmin Connext Weather service offers worldwide weather coverage, but the availability of individual weather products, such as radar precipitation, varies by region.
To check the availability of Garmin Connext weather products offered in a particular region, visit flyGarmin.com®.
- Weather Product Age
- Datalink Weather
- NEXRAD
- Cloud Tops
- MEATARs and TAFs
- Datalink Lightning
- Winds Aloft
- Turbulence (FIS-B)
- Icing (FIS-B)
- Temporary Flight Restrictions (TFRs)
- PIREPs and AIREPs
- Graphical AIRMETs (FIS-B)
- AIRMETs (FIS-B)
- Center Weather Advisories (CWAs) (FIS-B)
- Abnormal Operations (FIS-B)
