Radio Altimeter (RA)/Radio AGL (RAGL)
CAUTION
A Garmin Height Above Ground Sensor (GHA) will also provide the indications mentioned in this section but is NOT considered a radio altimeter.
NOTICE
The GHA only provides a radio AGL from 0 to 500 feet.
NOTICE
Radio altimeter functionality is optional. A radio altimeter must be installed and configured for this section to apply.
When the RA/RAGL height (aircraft altitude above ground level detected by the RA/RAGL) is between zero and 2500 feet, the current AGL value is displayed below the altimeter. Display of RA/RAGL height becomes more sensitive as the height above ground decreases.
Table 8: Radio Altimeter Sensitivity
Radio Height Range
Shown to Nearest
0 to 50 feet
1 foot
50 to 200 feet
5 feet
200 to 1500 feet
10 feet
1500 to 2500 feet
50 feet
When the RA/RAGL is selected as the altitude source for the minimum altitude alerting function, the color scheme of the minimums window is the same as the other barometric minimum alerts.
A ground line with diagonal stripes below it appears on the Altimeter to show the aircraft's height above the ground. If the RA/RAGL data becomes invalid, the message 'RA FAIL' is displayed in amber in place of the current AGL height. If a GHA is installed and data becomes invalid, the message 'RAGL FAIL' is displayed in amber in place of the current RAGL height.
59: Altimeter Displaying the Ground Line (Radio Alt)
60: GHA Installed with Invalid Data
190-03123-21 Rev B
October 2026
