Adding a Track
You can add a track that is not already loaded on your device. The device uses your GPS location and your vehicle's movements to create a map of the track.
  1. Select Drive > Add a Track.
  2. Follow the on-screen instructions to enter track details and information about your drive session.
  3. Select Start.
  4. Start driving.
    Once you exit the pit area and enter the track, you must drive in a straight line for at least 0.5 seconds at a minimum of 55 mph (90 km/h) and complete one full lap.
  5. Select END after you have completed the drive session.
  6. Select Forward or Back to position the starting line on the map.
  7. Select Save.
Copyright © Garmin. All rights reserved.GUID-16C78876-E016-40FD-8A0A-049BA52B462B v6
