Identifying the Contents
CAUTION
To avoid potential injury or property damage, a two-person lift is required.
  1. Remove the accessory box and top foam insert from the internal packaging.
    The accessory box contains the spare hardware packet and floor spikes kit.
    • The spare hardware packet 1 contains spare screws and two hex keys. You should use the spare screws if the original screws are damaged during installation.
    • The floor spikes kit 2 contains optional spikes for use on different surfaces (Optional Floor Spikes).
    Exploded view of the stand, top, and included parts with callouts
  2. Using the two cutouts in the top wooden panel as handles, carefully lift and remove the stand from the carton.
  3. Open the cardboard wrap 3 at the base of the stand and remove the stand from the bottom foam insert.
  4. Using the included hex key, remove and discard the top wooden panel 4 from the stand.
GUID-01BDC3A7-6C48-4F80-BE5C-BD0E0D7E0CE7 v2
May 2026
