The status LED turns red while charging
  • Check the USB cable, connectors, and ports for damage.
  • Make sure the power source is generating power.
    You can check this several ways. For example, you can check whether other devices powered by the source are functioning.
  • Make sure the device is within the approved charging temperature range (Varia RTL and RDU Specifications).
Copyright © Garmin. All rights reserved.GUID-7E1115F1-0B47-4A1C-9793-E86AD436B6C7 v3
