Setting the Bottom Search Limit
You can set a maximum depth at which the auto range feature searches for the bottom. A lower limit acquires data about the bottom faster than a higher limit.
  1. From a sonar screen, select Menu button > Sonar Setup > Bottom Search Limit.
  2. Select a range.
Copyright © Garmin. All rights reserved.GUID-A511BBA3-36BB-4303-8A1F-A676E13CB451 v5
