Viewing Weather Conditions and Forecasts
To view forecast and weather radar information, your device must have an internet connection. You can connect to a smartphone with internet access (Pairing Your Smartphone). You can also connect to a wireless network.
You can view weather conditions and forecasts, and view weather radar on the map. When the map is dark, no weather data is loaded on the device, or the device is out of coverage. Weather data is not available for out-of-coverage areas on the map.
When you view a weather radar frame, the device displays the current time for the frame.
- From the app drawer, select Weather.
Select an option:
To view the weather radar on the map, select
TIP: You can animate or pause the weather map. When you stop the animation, the device displays the most recent weather data. -
To view current weather conditions and forecasts, select
Parent Topic: Applications
