LiveScope and Perspective Layout Settings
From the LiveScope or Perspective sonar view, select Options > Sonar Setup > Layout.
Grid Overlay
Shows a grid of range lines. The Grid option shows a square grid. The Radial option shows a circular grid with radial angle lines.
Scroll History
Shows the sonar history on the side of the screen. Not available in Perspective mode.
Beam Icon
Selects the icon used to show the direction of the transducer beam.
Beam Overlay
Enables an outline to show where the transducers are oriented in relation to each other, when two or more calibrated Panoptix™ transducers are connected.
On-screen Control
Shows the on-screen buttons.
Reverse Range
Adjusts the amount of range shown behind the transducer.
Compress Range
In forward views, compresses the forward range farther away from the boat and expands the range closer to the boat. This allows you to see closer objects more clearly while keeping farther objects on the screen.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
