LiveScope and Perspective Sonar Settings
From the LiveScope or Perspective sonar view, select Options.
Gain
Controls the level of detail and noise shown on the sonar screen.
If you want to see the highest intensity signal returns on the screen, you can lower the gain to remove lower intensity returns and noise. If you want to see all return information, you can increase the gain to see more information on the screen. Increasing the gain also increases noise, and can make it more difficult to recognize actual returns.
Depth Range
Adjusts the range of the depth scale.
Allowing the device to adjust the range automatically keeps the bottom within the lower portion of the sonar screen, and can be useful for tracking a bottom that has minimal or moderate terrain changes.
Manually adjusting the range enables you to view a specified range, which can be useful for tracking a bottom that has large terrain changes, such as a drop-offs or cliffs. The bottom can appear on the screen as long as it appears within the range you have set.
Available in LiveScope sonar view.
Forward Range
Adjusts the range of the forward scale.
Allowing the device to adjust the range automatically adjusts the forward scale in relation to the depth. Manually adjusting the range enables you to view a specified range. The bottom can appear on the screen as long as it appears within the range you have set.
Range
Adjusts the range.
Allowing the device to adjust the range automatically keeps the bottom within the lower or outer third of the sonar screen, and can be useful for tracking a bottom that has minimal or moderate terrain changes.
Available in Perspective sonar view.
Transmit
Stops the active transducer from transmitting.
Sonar Setup
Adjusts the setup of the transducer and the appearance of the sonar returns (LiveScope and Perspective Sonar Setup).
Edit Overlays
Adjusts the data shown on the screen (Customizing the Data Overlays).
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
