Showing Satellite Imagery on the Navigation Chart
NOTE:
This feature is available with premium charts, in some areas.
You can overlay high-resolution satellite images on the land or on both land and sea portions of the Navigation chart.
NOTE:
When enabled, high-resolution satellite images are present only at lower zoom levels. If you cannot see high-resolution images in your optional chart region, you can select
to zoom in. You also can set the detail level higher by changing the map zoom detail.
- From the Navigation chart, select .
Select an option:
Select Land Only to show standard chart information on the water, with photos overlaying the land.
Select Photo Map to show photos on both the water and the land at a specified opacity. Use the slider bar to adjust the photo opacity. The higher you set the percentage, the more the satellite photos cover both land and water.
Parent Topic: Premium Charts
