Customizing the Data Screens You can show, hide, and change the layout and content of data screens for each activity. Select START. Select an activity. Hold . Select the activity settings. Select Data Screens. Select a data screen to customize. Select an option: Select Layout to adjust the number of data fields on the data screen. Select a field to change the data that appears in the field. Select Reorder to change the location of the data screen in the loop. Select Remove to remove the data screen from the loop. If necessary, select Add New to add a data screen to the loop. You can add a custom data screen, or select one of the predefined data screens. Parent Topic: Activity Settings
Customizing the Data Screens You can show, hide, and change the layout and content of data screens for each activity. Select START. Select an activity. Hold . Select the activity settings. Select Data Screens. Select a data screen to customize. Select an option: Select Layout to adjust the number of data fields on the data screen. Select a field to change the data that appears in the field. Select Reorder to change the location of the data screen in the loop. Select Remove to remove the data screen from the loop. If necessary, select Add New to add a data screen to the loop. You can add a custom data screen, or select one of the predefined data screens. Parent Topic: Activity SettingsHomeCustomizing Your DeviceActivity SettingsCustomizing the Data Screens
