Going for a Run Using a Foot Pod
Before you go for a run, you must pair the foot pod with your device (Pairing Your ANT‍+ Sensors).
You can run indoors using a foot pod to record pace, distance, and cadence. You can also run outdoors using a foot pod to record cadence data with your GPS pace and distance.
  1. Install your foot pod according to the accessory instructions.
  2. If necessary, turn off GPS (Training Indoors).
  3. Select Runner symbol to start the timer.
  4. Go for a run.
  5. After you complete your run, select Runner symbol to stop the timer.
Copyright © Garmin. All rights reserved.GUID-0B08B4AE-BDDB-4FCE-91C9-3D320A32397F v7
