Pairing Your ANT‍+ Sensors
Before you can pair, you must put on the heart rate monitor or install the sensor.
Pairing is the connecting of ANT‍+® wireless sensors, for example, connecting a heart rate monitor with your Garmin® device.
  1. Bring the device within range (3 m) of the sensor.
    NOTE: Stay 10 m away from other ANT‍+ sensors while pairing.
  2. Select Menu > Settings > Sensors > Add Sensor.
  3. Select a sensor.
    When the sensor is paired with your device, a message appears. You can customize a data field to display sensor data.
Copyright © Garmin. All rights reserved.GUID-0B08B4AE-BDDB-4FCE-91C9-3D320A32397F v7
