Before you can view running dynamics, you must put on the
HRM-Run™ accessory and pair it with your device (Pairing
ANT+ Sensors). If your
fēnix® 3 was packaged with the accessory, the devices are already paired, and the
fēnix 3 is set to display running dynamics.
Select an option:
If your
HRM-Run accessory and
fēnix 3 device are already paired, skip to step 8.
If your
fēnix 3 device are not already paired, complete all the steps in this procedure.
Hold
UP.
Select
Select an activity.
Select
Data Screens.
Select a running dynamics data screen.
NOTE:
The running dynamics screens are not available for all activities.
Select
Go for a run (Going for a Run).
Select
UP or
DOWN to open a running dynamics screen to view your metrics.
