Putting On the Heart Rate Monitor
NOTE:
If you do not have a heart rate monitor, you can skip this task.
You should wear the heart rate monitor directly on your skin, just below your sternum. It should be snug enough to stay in place during your activity.
After you put on the heart rate monitor, it is active and sending data.
TIP:
If the heart rate data is erratic or does not appear, see the troubleshooting tips (Tips for Erratic Heart Rate Data).
Parent Topic: ANT+ Sensors
