Navigating Back to Start At any point during your ride, you can return to the starting point. Go for a ride (Going for a Ride). Select to pause the ride. Select Back to Start. Select Along Same Route or Straight Line. Select to resume your ride. The device navigates you back to the starting point of your ride. Parent Topic: Locations
Navigating Back to Start At any point during your ride, you can return to the starting point. Go for a ride (Going for a Ride). Select to pause the ride. Select Back to Start. Select Along Same Route or Straight Line. Select to resume your ride. The device navigates you back to the starting point of your ride. Parent Topic: LocationsHomeNavigationLocationsNavigating Back to Start
