Going for a Ride
If your device was packaged with an ANT‍+® sensor, they are already paired and can be activated during initial setup.
  1. Hold Power symbol to turn on the device.
  2. Go outside, and wait while the device locates satellites.
    GPS status symbol appears solid when the device is ready.
  3. From the home screen, select Start symbol.
  4. Select Start symbol to start the activity timer.
    Activity timer with bike data
    NOTE: History is recorded only while the activity timer is running.
  5. Select Start symbol to stop the activity timer.
  6. Select an option:
    • Select Resume to resume your ride.
    • Select Save Ride to stop your ride and save it.
      TIP: You can select the ride type. Accurate ride type data is important for creating bike friendly courses on your Garmin Connect™ account.
    • Select Discard Ride to stop your ride and delete it from your device.
    • Select Back to Start to navigate back to your starting location.
    • Select Mark Location to mark your location and save it.
Copyright © Garmin. All rights reserved.GUID-81BCB159-365D-4431-B311-F7B95B30F710 v4
