From the watch face, press
Select a dive mode (Dive Modes).
If necessary, press
DOWN to edit the dive settings, such as the gases, water type, and alerts (Dive Setup).
Wait with your wrist out of the water until the device acquires GPS signals and the status bar turns green (optional).
The device requires GPS signals to save your dive entry location.
Press
until the primary dive data screen appears.
Descend to start your dive.
The activity timer starts automatically when you reach a depth of 1.2 m (4 ft.).
NOTE:
If you start a dive without selecting a dive mode, the device uses the most recently used dive mode and settings, and your dive entry location is not saved.
Select an option:
Press
DOWN to scroll through the data screens and dive compass.
TIP:
You can also double tap the device to scroll through the screens.
Press
to view the in-dive menu.
When you ascend to 1 m (3.3 ft.), the
End Dive Delay timer begins counting down (Dive Setup). When the timer elapses, the device automatically ends and saves the dive. You should keep your wrist out of the water while the device saves your dive exit location.
