Using the inReach Remote
Before you can use the inReach® remote function, you must set the inReach widget to be shown in the widget loop (Customizing the Widget Loop).
  1. Turn on the inReach device.
  2. On your D2™ device, select UP or DOWN from the watch face to view the inReach widget.
  3. Select Start to search for your inReach device.
  4. Select Start to pair your inReach device.
  5. Select Start, and select an option:
    • To send an SOS message, select Initiate SOS.
      NOTE: You should only use the SOS function in a real emergency situation.
    • To send a text message, select Messages > New Message, select the message contacts, and enter the message text or select a quick text option.
    • To send a preset message, select Send Preset, and select a message from the list.
    • To view the timer and distance traveled during an activity, select Tracking.
Copyright © Garmin. All rights reserved.GUID-EF62730A-5896-4ECB-9BD8-3CFCE26AA485 v4
