Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. Hold MENU.
  2. Select Settings > Widgets.
  3. Select a widget.
  4. Select an option:
    • Select Reorder to change the location of the widget in the widget loop.
    • Select Remove to remove the widget from the widget loop.
  5. Select Add Widgets.
  6. Select a widget.
    The widget is added to the widget loop.
Copyright © Garmin. All rights reserved.GUID-EF62730A-5896-4ECB-9BD8-3CFCE26AA485 v4
