Editing a Hub
You can edit the trip details for a hub.
NOTE: The departure and arrival times shown in the hubs reflect the actual time at the location, based on the local time zone.
  • To change a departure time for a hub, select a departure point, and select Edit via point.
  • To change an arrival time for a hub, select an arrival point, and select Edit via point.
  • To change the method of travel for a hub, select a departure point, and select the icon for the method of travel.
    NOTE: You can add multiple methods of travel to your trip by adding additional hubs and changing the method of travel in each hub.
  • To add a day to a hub, select Add next to the hub name.
  • To remove a day from a hub, right-click the day, and select Delete.
  • To re-order days, departure points, arrival points, and exit points, drag the item to any place in the trip.
Copyright © Garmin. All rights reserved.GUID-85180353-4CB9-4530-857B-7708A71D12AB v5
