Setting Up the Alpha 100F System
NOTICE
Avoid using a high-powered radio (greater than 5 watts) in close proximity to the device. It may cause irreversible damage to the device.
Before you can use the Alpha® 100F handheld device and the T5F dog collar device, you must set up the devices.
  1. Install the battery in the handheld device (Installing the Battery Pack).
  2. Charge the handheld device (Charging the Handheld Device).
  3. Charge the dog collar device (Charging the Dog Collar Device).
  4. Turn on the devices (Turning On the Devices).
  5. If necessary, add the dog collar device to the handheld device (Adding a Dog to the Alpha 100F Handheld Using Wireless Pairing).
  6. Acquire satellite signals (Acquiring Satellite Signals).
  7. Attach the collar (Fitting the Collar on Your Dog).
Copyright © Garmin. All rights reserved.GUID-D06D22DA-E385-4AEC-B773-07A78364302D v2
